NAC 552
Performance without limits.
Our preamplifiers epitomise everything we believe in. Starting with our revolutionary NAC 12 back in 1974, Naim Audio preamplifiers have both rewritten the rules and set the standards for others to follow. The NAC 552 is second only to our Statement NAC S1: its distinctive two-box configuration marks it out from the competition just as surely as its unfettered musicality reflects our core values. It's one of the best preamplifiers we’ve ever produced, and by extension, among the best in the world.
View full 500 Series range >
Share
Features
  • Two-box configuration for optimum rejection of electromagnetic interference
  • Split-rail power supply featuring 800VA toroidal transformer, three smoothing capacitors and new Discrete Regulator (DR)
  • Fully suspended sub-chassis for superior isolation of sensitive circuit boards
  • AV bypass mode for simple connection to an existing AV system
  • Support for both DIN and RCA inputs to facilitate connection into a wider range of systems
  • Independent listen and record banks for maximum flexibility
  • Assignable inputs for enhanced usability with a range of sources
NAC 552 Separate Preamplifier
Technology & Craft
Like every component in our flagship 500 Series range, the NAC 552 has been developed without compromise or constraint. Its two-box design, which houses the power supply components in a separate enclosure to better control electromagnetic interference, is classically Naim Audio. By contrast, the 552 PS DR power supply itself employs radically new thinking, including a new split-rail configuration that virtually eliminates power supply noise in the signal earth.
The sound-critical electronics of the NAC 552 are mounted on a brass sub-chassis, which is fully suspended on coil springs at a frequency below the threshold of human hearing. This method of suspension maximises isolation, hence minimizing the effect of vibration on the highly sensitive electronic components. Carefully selected precision rotary potentiometers with precious metal wipers are used to preserve music integrity and ensure long-term stability.
The NAC 552’s six inputs can be selected directly from either the front panel or the remote control. In addition to the usual DIN inputs, preferred for their superior earthing and impedance matching, the NAC 552 owner can configure two of the inputs for use with the more common RCA phono type connectors, enabling the use of alternative components with pre-owned interconnects.
Product Specification
NAC 552
Audio Inputs
Attribute Value
Other Inputs
Two inputs configurable for unity gain
Input Impedance
47kΩ
Analogue
7 x DIN, 2 x RCA
Input Sensitivity
75mV
Audio Outputs
Attribute Value
Audio Outputs
1 x variable, 3 x fixed (DIN)
Line Outputs Variable (level)
775mV
Line Outputs Fixed (level)
75mV, 600Ω
Load Impedance
10kΩ (min.)
Output Impedance
<50Ω
Power Outputs
Naim phono amplifier
Connectivity
Attribute Value
RS232
Optional (DE9 female)
Remote Input
RCA on rear (RC5)
Finish
Attribute Value
Case
Brushed and black anodised
Front
Physical
Attribute Value
Weight
12.9 kg
Dimensions (HxWxD)
87 x 432 x 314 mm
Power
Attribute Value
Power Supply Options
552 PS
Supply Voltage
+/-12V, 24V, 32V
Supplied with
Attribute Value
Supplied with
552 PS, Power-Line, R-Com and Burndy
Upgrades
Attribute Value
Power Supply
552 PS
User Control
Attribute Value
Front Panel
Volume control, balance control, sixteen button matrix
Handheld
NARCOM-4 Remote Control
Remote Control
Infra Red (RC5)
552 PS
Audio Outputs
Attribute Value
Power Outputs
7 x +/-12V, 1 x 12V, 2 x 24V, 1 x 31V
Finish
Attribute Value
Case
Front
Physical
Attribute Value
Shipping Weight
17.5 kg
Shipping Dimensions
240 x 590 x 500 mm
Dimensions (HxWxD)
87 x 432 x 314 mm
Power
Attribute Value
Mains Supply
100V, 115V, 230V; 50 or 60Hz
Supplied with
Attribute Value
Supplied with
R-Com, Power-Line, SNAIC
Suggested System
A Naim Audio Retailer will recommend the right system for you, however you may choose to partner the NAC 552 with the following as a start:
  • Utopia III
  • ND 555
  • NAP 500 DR
  • 555 PS DR
Manuals & Downloads
Book a Demo
Find Your Nearest Retailer
Please complete the form below to arrange an appointment with your chosen retailer.
By submitting your contact details, you agree for us to share your details with our retail partners, who will contact you directly to arrange your appointment. For full details on how your data is shared please review our privacy policy
Customer Reviews
Newsletters Sign Up
