NAP 100 Discontinued
The NAP 100 has been discontinued but remains a classic expression of traditional Naim Audio power amplifier engineering. While its dimensions are conveniently compact – just a mere 20cm wide – its performance is seriously dynamic and expansive.
The NAP 100 is perfect for a number of applications, adding a dose of Naim Audio musicality to a wide variety of systems. Paired with our DAC-V1 digital-to-analogue converter, it becomes the power behind a high-end system to unleash the music from your PC or Mac. Add a UnitiServe to the equation and you create a full hi-fi system that divorces your listening experience from the desktop and allows you complete control from our n-Serve iOS app.
- 50W per channel output into 8 ohms
- Dual mono power amplifier design
- Audiophile grade hand-selected components
- Linear power supply with a large toroidal transformer
- Pair with the DAC-V1 and UnitiServe for compact, high-end music system
Despite its small size, the NAP 100 packs a serious punch when it comes to sound quality. Delivering 50 watts per channel into 8 Ohms, and 75 watts into 4 Ohms, its dual mono design is based on the circuit topology found in our reference all-in-one player, the SuperUniti.
Our engineers also took inspiration from classic Naim Audio power amplifier design in developing the NAP 100. A large toroidal transformer and hand-matched, hand-wired critical componentry allow it to bring new levels of clarity and vitality to your music.
Product Specification
Attribute Value | |
Input Impedance |
18kΩ |
Analogue Input |
1 x 4-pin DIN, 1 x RCA pair |
Attribute Value | |
Minimum Load Impedance |
2Ω |
Frequency Response |
-3dB at 3.5Hz - 69kHz |
Gain |
+29dB |
Attribute Value | |
Case |
Black powder coated |
Front |
Attribute Value | |
Shipping Weight |
7.6 kg |
Shipping Dimensions |
210 x 280 x 410 mm |
Weight |
5.1 kg |
Dimensions (HxWxD) |
87 x 207 x 314 mm |
Attribute Value | |
Mains Supply |
115V or 230V, 50 or 60Hz |
Power Consumption |
260VA |
Power Consumption (quiescent) |
15VA |
Attribute Value | |
Speaker Outputs |
L & R, 4mm “banana” sockets |
Speaker Outputs |
50W per channel into 8Ω, 75W per channel into 4Ω |
Attribute Value | |
Supplied with |
SNAIC, Power-Line Lite mains cable (UK denominations only) |
Suggested System
A Naim Audio Retailer will recommend the right system for you, however you may choose to partner the NAP 100 with the following as a start:
Manuals & Downloads
Brochures
How to Guide
Product Manuals
Reviews & Awards
Book a Demo
Find Your Nearest Retailer
Please complete the form below to arrange an appointment with your chosen retailer.
Customer Reviews
Newsletters Sign Up
