NAP V145 Mono Power Amplifier
NAP V145
Discontinued
The NAP V145 is our mono power amplifier for use with multichannel AV systems. It shares the circuit layout and key components of our acclaimed NAP 250 and is every bit as transparent and articulate, yet provides even greater dynamics.
During the years of research that went into the flagship NAP 500, many technical developments came about that have been successfully applied to the NAP V145. Based around the circuit topology of the latest NAP 250, the NAP V145 provides even greater dynamic capabilities and enhanced audio performance, resulting in the perfect solution for high quality multi-channel or active high-end systems.
Like the NAP 500, the NAP V145 uses a new circuit design with improved earthing arrangements, built on a high quality, anti-resonance main audio circuit board. It uses the same 007 transistors that were custom-designed for the NAP 500. These outstanding components each provide up to 80 Amps and 350 watts, negating the need to use parallel pairs of transistors (which always have a negative effect on sound). Additional 007 transistors are used in the fully regulated power supply, ensuring the best performance.
Anti-vibration, resonance-controlling feet serve to protect the sensitive internal components from resonance and microphonic vibration. A new top-quality transformer is used providing the ability to swing a massive 400 VA on transients. Furthermore, the NAP V145 is stable into any load and can drive a 2-Ohm load for long periods of time.
Share
Features
  • 80W (mono) output into 8 ohms
  • Large custom-designed transformer providing 400VA of transient power
  • Advanced 007 output transistors, as used in our reference NAP 500 power amplifier
Product Specification
Audio Inputs
Attribute Value
Input Impedance
18kΩ
Analogue Input
1 x XLR
Audio Outputs
Attribute Value
Minimum Load Impedance
Frequency Response
 -3dB at 3Hz - 50kHz
Gain
+29dB
Finish
Attribute Value
Case
Black powder coated
Front
Brushed and black anodised
Physical
Attribute Value
Shipping Weight
17.3 kg
Shipping Dimensions
240 x 590 x 500 mm
Weight
15.8 kg
Dimensions (HxWxD)
87 x 432 x 314 mm
Power
Attribute Value
Mains Supply
100V, 115V, 230V; 50 or 60Hz
Speaker Outputs
Attribute Value
Power Output
80W (mono amplifier), 8Ω
Transient
400VA
Speaker Outputs
L & R, 4mm “banana” sockets
Supplied with
Attribute Value
Supplied with
Standard Interconnect
Manuals & Downloads
Newsletters Sign Up
