NAT05 XS Radio Tuner
NAT05 XS
Discontinued
Styled to match the rest of our XS Series range, the NAT05 XS draws on a rich heritage of performance-oriented tuner design. Its layout and specification exemplify the purity of purpose we have been refining for over 25 years. At the heart of the NAT05 XS lies the high-performance ALPS tuner head. When teamed with a good-quality roof aerial, it ensures that our latest tuner ranks among the world's best sounding radio sources. The clean, articulate and effortlessly musical presentation of the NAT05 XS does full justice to any quality hi-fi system.
Share
Features
  • Remote handset plus preset station storage memory
  • Premium ALPS tuner head for maximum performance
  • Selectable DIN or phono outputs
  • Performance upgradable with external FlatCap XS
Technology & Craft
We have a rich history in radio. One of our very first products, the NAM 502 loudspeaker, was specifically designed for use by then start-up station Capital Radio in 1973. It was a natural progression for us to design tuners that would capture and preserve every nuance of the medium. The NAT 101 of 1986 was an early example. What earned these tuners such a loyal following was the simplicity of design and quality of sound - traits that put their successors in good stead to lead the high-end market all the way up to the current NAT05 XS.
Product Specification
Audio Inputs
Attribute Value
Tuning Range
FM 87.5 - 108MHz
Antenna
FM
Audio Outputs
Attribute Value
De-emphasis
50μs for 230V or 75μs for 115V
Line Outputs Fixed (level)
600mV RMS at 100% modulation
100Ω (max.)
Analogue
DIN, RCA
Signal-to-Noise Ratio
67dB at 1mV RF input level
THD
<0.8%
Minimum Load Impedance
10kΩ
Connectivity
Attribute Value
Remote Input
1 x 3.5mm jack on rear (RC5 modulated/unmodulated)
Finish
Attribute Value
Case
Black powder coated
Front
Brushed and black anodised
Physical
Attribute Value
Shipping Weight
7.85 kg
Shipping Dimensions
200 x 590 x 500 mm
Weight
5.5 kg
Dimensions (HxWxD)
70 x 432 x 301 mm
Power
Attribute Value
Mains Supply
115V, 230V; 50 or 60Hz
Power Consumption
15VA
Supplied with
Attribute Value
Supplied with
NARCOM-4, Standard Interconnect, Power-Line Lite mains cable (UK denominations only)
Upgrades
Attribute Value
Power Supply
FlatCap XS, HiCap, SuperCap
User Control
Attribute Value
Front Panel
Four button matrix
Remote Control
Infra Red (RC5)
Manuals & Downloads
Newsletters Sign Up
