ND5 XS Network Player
ND5 XS
Discontinued
The ND5 XS is our introduction to network music streaming, but still benefits from classic Naim Audio engineering principles and fastidious attention to detail in every aspect of its layout and design.
It also loses none of the flexibility or functionality of its illustrious siblings. High-resolution UPnP network streaming, Spotify Connect built-in, USB playback, access to thousands of internet radio stations, DAB/FM radio, digital inputs for external sources, native support for TIDAL high fidelity music streaming service, multiroom streaming and a bespoke iOS and Android control app will get you listening to more music than ever before.
Share
Features
  • UPnP-enabled to allow streaming of audio files at up to 24bit/192kHz resolution from Naim Audio hard disk servers, network-attached storage (NAS) devices or any home computer
  • Supports a broad range of music formats: WAV, FLAC, DSD (single rate), Apple Lossless, AIFF, AAC, Windows Media-formatted files, Ogg Vorbis and MP3. Gapless playback on all lossless file formats and on most compressed music
  • Three 24bit/192kHz capable digital inputs (S/PDIF) to support optimum connection to external sources
  • Spotify Connect built-in to stream millions of songs from the world’s most popular streaming service
  • Native support for TIDAL streaming service with free 90 day trial of lossless HiFi tier
  • Front-panel USB port for replay of MP3 player and USB-stored audio
  • vTuner 5* full-service internet radio
  • Optional DAB+/DAB/FM radio module
  • Multiroom & Party Mode compatible
  • iOS and Android Naim Audio app for intuitive control
  • Bluetooth connectivity with aptX codec for quality audio playback
Technology & Craft
Like the NDX, the ND5 XS is one of the most technically advanced and accomplished of all Naim Audio products. The use of numerous innovative techniques for electronic signal processing and isolation ensure that each digital audio data stream is delivered to the ND5 XS outputs with maximum fidelity. The ND5 XS uses the same RAM buffer and master-clock jitter removal technique of the Naim Audio DAC and all the oversampling, filtering and signal management techniques that have brought Naim Audio to the forefront of digital music in the home.
And the result of all this extraordinary technology is extraordinary music reproduction. Connect an ND5 XS to your existing audio system and the world of high resolution audio downloads, UPnP streaming, and the vast resource of internet radio are yours for the listening. And it's a world where music from any source will live, breath and satisfy - completely.
Please note: only current "Classic" style XPS power supplies can be used with the ND5 XS. Older "Olive" style XPS units are incompatible and cannot be used.
Product Specification
Audio Inputs
Attribute Value
Antenna
Wi-Fi (802.11 g or n at 2.4GHz), F type (plus PAL adapter) on tuner version
UPnP
Wired Ethernet (RJ45) or Wi-Fi
USB
1 x front panel Type A socket
Digital (S/PDIF)
3 x S/PDIF:
   - 1 x coaxial BNC - up to 24bits/192kHz
   - 1 x coaxial RCA - up to 24bits/192kHz
   - 1 x optical TOSLINK - up to 24bits/96kHz
Audio Outputs
Attribute Value
THD + N
<0.02%, 10Hz - 20kHz at full level
Load Impedance
10kΩ (min.)
Output Impedance
22Ω (max.)
Analogue
1 x DIN and 1 x RCA, 2.1V RMS at 1 kHz
Digital (S/PDIF)
1 x BNC (75Ω)
Frequency Response
10Hz - 20kHz, +0.1/−0.5dB
Connectivity
Attribute Value
Updates
1 x USB Type Mini-B
Remote Output
2 x rear panel 3.5mm jack (RC5 modulated or unmodulated)
Remote Input
1 x rear panel 3.5mm jack (RC5 modulated and unmodulated)
Formats
Attribute Value
Multiroom
Master: Will stream WAV, FLAC and AIFF (up to 24bit/48kHz), ALAC (up to 16bit/44.1kHz), AAC and MP3 (up to 16bit/48kHz) files only as MP3 320kbps quality.
FM Tuning Range
(optional module) 87.5 - 108MHz
DAB Tuning Range
(optional module) Band III and L Band
Internet Radio Provider
vTuner 5* full service
Audio Formats
WAV (up to 24bit/192kHz)
AIFF (up to 24bit/192kHz)
FLAC (up to 24bit/192kHz)
DSD (single rate DSF64 & DFF64 only)
ALAC (up to 24bit/96kHz)
WMA (up to 16bit/48kHz) must be WMA 9.2
Ogg Vorbis (up to 16bit/48kHz)
M4a (CBR and VBR up to 320kbit/s)
MP3 (CBR and VBR up to 320kbit/s)
Playlists (M3U, PLS)
Physical
Attribute Value
Weight
6.5 kg
Dimensions (HxWxD)
70 x 432 x 301 mm
Power
Attribute Value
Power Consumption
60VA (max.)
Supply Voltage
100V, 115V, 230V; 50 or 60Hz
Supplied with
Attribute Value
Supplied with
Uniti Remote Control, Standard Interconnect
Upgrades
Attribute Value
Power Supply
XP5 XS, XPS, 555 PS
Other
DAC digital to analogue converter, Hi-Line, Power-Line Lite mains cable (UK denominations only)
User Control
Attribute Value
Front Panel
Nine button matrix
Handheld
Remote handset included and optional Naim app for iOS and Android.
Remote Control
Infra Red (RC5)
Suggested System
A Naim Audio Retailer will recommend the right system for you, however you may choose to partner the ND5 XS with the following as a start:
  • NAIT XS 2
  • CD5 XS
  • Aria 900
Manuals & Downloads
Reviews & Awards
Latest Reviews
Hi-Fi Critic Best Buy and Audio Excellence, Apr 2015
"Naim is on a roll with its versatile collection of streamers. The ND5 XS works really well straight out of the box..."
AVForums, Apr 2013
"It is unconditionally stable, beautifully built and capable of exceptional performance with both lossless and high resolution material."
Hi-Fi Choice, Nov 2011
"The way the ND5 XS makes music simply makes you feel good to be alive"
Awards
What Hi-Fi? Awards 2016 | Best Music Streamer £2000+
What Hi-Fi? Awards 2015 l Best Streamer £1500+
Queen's Award for Innovation
AVForums Highly Recommended
HiFi Choice Winner Award 2011
Newsletters Sign Up
