NDX 2
Streamlined connectivity from an exceptionally engaging network player
With its world-class performance, the versatile and upgradable NDX 2 embodies the current state of the art. A host of features such as high-res UPnPTM streaming, AirPlay, AirPlay 2, Chromecast built-in, Bluetooth (aptX HD), Spotify Connect, TIDAL, Qobuz, Roon compatibility, vTuner internet radio and multiroom streaming as well as digital and USB inputs provide all the connectivity you could wish for.
Our main focus in developing the NDX 2 network player, however, was its performance. Along with Naim’s bespoke streaming platform, we implemented an upgraded DAC and discrete analogue stages. These and numerous other improvements over its acclaimed predecessor make the NDX 2 a sonic force to be reckoned with, offering highly immersive and lively replay quality.
Share
Features
  • UPnP-enabled to allow streaming of audio files at up to 32bit/384kHz resolution from Naim Audio hard disk servers, network-attached storage (NAS) devices or any home computer
  • Supports a broad range of music formats: WAV, FLAC, DSD, Apple Lossless, AIFF, AAC, Windows Media-formatted files, M4A and MP3. Gapless playback on all file formats
  • Four 24bit/192kHz capable digital inputs (S/PDIF) to support optimum connection to external sources
  • 5” colour display presenting album artwork as well as track information
  • Built-in Chromecast allows you to stream from hundreds of supported smartphone or tablet apps (192kHz)
  • Apple AirPlay - stream music from your iOS device or from iTunes and Apple Music
  • Spotify Connect built-in to stream millions of songs from the world’s most popular streaming service
  • Native support for Qobuz with true high-res streaming up to 24-bit/192kHz quality.
  • Native support for TIDAL streaming service with free 90 day trial of lossless HiFi tier
  • Front-panel USB port for replay of MP3 player and USB-stored audio (1.6A charge)
  • vTuner 5* full-service internet radio
  • Multiroom & Party Mode compatible
  • iOS and Android Naim Audio app for intuitive control
  • Bluetooth connectivity with aptX HD codec for quality audio playback
  • Thanks to RC5 system integration, you can control compatible amplifiers that are connected to your network player directly from the Naim app on a phone or tablet.
  • Bi-directional, Zigbee®-compatible remote control
  • Roon ready - turning your music collection into a beautifully laid out catalogue
Technology & Craft
The Burr-Brown® PCM1792A digital-to-analogue converter working alongside our new streaming platform is one of the best available. We improved its performance even further by implementing our own digital filters and adding a discrete current-tovoltage converter immediately after the DAC.
The streaming section of the NDX 2 uses the latest Naim network card featuring lownoise, high-speed low-voltage differential signalling (LVDS) to route the digital audio signal. The higher speed is capable of decoding all HD audio formats at up to 32 bits/384 kHz or DSD128. Rather than the source acting as the digital timing master, our new streaming board turns things around and allows our DAC clock to control the flow of audio data. The data is integer-over-sampled in a SHARC DSP to an incredible 40-bit accuracy before it’s fed to the Burr-Brown DAC.
The NDX 2 features an integrated low-noise power supply with a custom-designed toroidal transformer and separate windings for the digital and analogue sections. However, the player can be upgraded with an external XPS DR or 555 PS DR power supply, giving you a marked increase in sonic authority and emotion.
During the development of the NDX 2, our engineers examined every detail, from mechanical construction, component selection and board layout. The result is a network player worthy of the Naim badge, with a sound that’s rich, detailed and engaging.
Product Specification
Audio Inputs
Attribute Value
Streaming
Chromecast built-in, Apple AirPlay, TIDAL, Spotify® Connect, Bluetooth (AptX HD), Internet Radio, UPnP™ (hi-res streaming), Roon Ready
USB
2 x USB Type A socket (front and rear - 1.6A charge)
Digital (S/PDIF)
2 x Optical TOSLink (up to 24bit/96kHz)
1 x coaxial RCA (up to 24bit/192kHz, DoP 64Fs)
1 x coaxial BNC (up to 24bit 192kHz, DoP 64Fs)
Audio Outputs
Attribute Value
Analogue
1 x RCA pair
1 x 5-pin DIN
Digital       1 x coaxial BNC
Connectivity
Attribute Value
Updates
Update your system wirelessly via the Naim app
Network
Ethernet (10/100Mbps), WiFi (802.11 b/g/n/ac with external antennae)
Formats
Attribute Value
Multiroom
Party Mode Streaming: Sync up to six Naim products and control via the Naim app
Internet Radio Formats
Windows Media-formatted content, MP3, ACC, OGG Vorbis streams and MMS
Internet Radio Provider
vTuner premium 5*
Audio Formats
WAV - up to 32bits/384kHz
FLAC and AIFF - up to 24bit/384Hz
ALAC (Apple Lossless) - up to 24bit/384Hz
MP3 - up to 48kHz, 320kbit (16 bit)
AAC - up to 48kHz, 320kbit (16 bit)
OGG and WMA - up to 48kHz (16 bit)
DSD - 64 and 128Fs
M4A - up to 48kHz, 320kbit (16 bit)
Note: Gapless playback supported on all formats.
Physical
Attribute Value
Dimensions
87mm x 432mm x 314mm (H x W x D)
Finishes
Brushed and anodised aluminium
Weight
10kg
Power
Attribute Value
Power Consumption
Typical use: 19W
Network standby mode: <2W
Deep sleep: <0.5W
Ripping and Storage
Attribute Value
Storage
Supplied with
Attribute Value
Supplied with
Zigbee® remote (inc. batteries), Power-Line Lite cable (UK denominations only), Burndy link plug, 5-pin DIN interconnect cable, BNC to RCA adaptor, Wi-Fi (x2) and Bluetooth antennae, cleaning cloth, quick start guide
Upgrades
Attribute Value
Mains Cable
Power-Line
Power Supply
555 PS DR/ XPS/ XP5 XS
Other
Super Lumina / Hi-Line
User Control
Attribute Value
App Control
Naim App for iOS and Android
Front Panel
5" colour LCD display and four buttons
Handheld
Zigbee® RF4CE
Manuals & Downloads
Reviews & Awards
Latest Reviews
Hi-Fi World | NDX 2 | Best Network Player, Nov 2019
"It is both dynamic yet detailed, with a punch few other streamers can match."
HI-FI World | NDX 2 | 5 Globes , Sep 2019
"Sonically it was supremely well-honed, something of a reference for what is possible from streaming."
HI-FI+ | NDX 2/XPS DR | Review , May 2019
“The Naim reflects the intrinsic nature of both the recording and the music with everything you choose to play.”
What Hi-Fi? | NDX 2 | 5 Star Review, Feb 2019
'For most, a stand-alone Naim NDX 2 will be all the streamer they could ever want. It is well made, carefully conceived and sounds excellent for the money. Naim also has a great track record on supporting its products, which really matters when the investment is as heavy as this. In short, buy the NDX 2 with confidence.'
The Ear | NDX 2 | 5 Star Review, Feb 2019
'This is a fabulous streamer, use it with a very good server and you are guaranteed digital musical entertainment that will keep you enthralled for years. It shows you precisely what’s going on and brings out what’s special about the music, and that’s what you want from a piece of audio electronics.'
Fairaudio | NDX 2 | Hi-Fi Test , Nov 2018
Rather sonorous and razor-sharp pulse playback and analytical access to the air belt … is rather rare, right? No, just as the Naim does that, it seems coherent: music should come across tangibly, authentically and physically.
NDX 2 | Hi-Fi Critic, Sep 2018
Clarity, image depth precision and dynamics are a prime strength, while still greater resolution and improved timing may be had with those optional extra power supplies. An Audio Excellence rating seems appropriate for the NDX 2/555 PS DR combination.
Network Players Press Event | Hi-Fi+, Apr 2018
'First Listen – Naim ND5 XS 2, NDX 2, ND 555 streamers'
Awards
The Ear | NDX 2 | Best of 2019
Stereopluss | NDX 2 | Årets Produkt
Diapason | Uniti Atom & NDX 2 | Diapason d'Or 2018
Support
Customer Reviews
Newsletters Sign Up
