NPX TT
Dedicated power supply for NVC TT
Naim know-how
Naim know-how
Under the leadership of our Technical Director, our engineers have developed specific electronic circuits to give the New Classic products superior performance. The best audiophile components have been chosen and highly precise measurements to achieve an uncompromising result. Paired with the NVC TT, NPX TT provides even cleaner power to enhance the sound.
A timeless design
A timeless design
Naim products are designed to be both contemporary and timeless. Our creations forgo any unnecessary adornments that would detract from the performance and sound quality delivered. The design of the NPX TT is razor sharp, combining a sleek design, premium materials and adjustable logo brightness.
The story of Naim and aluminium
Our founder, Julian Vereker, immediately understood the many benefits of aluminium as a material for wrapping Naim electronic components. He knew that delicate audio components are very sensitive to the effects of magnetic fields, unstable temperatures, unwanted vibrations, etc.
The Naim Classic range maximises this highly technical and durable approach, with aluminium housings rivalled only by Statement, our flagship product. Naim chose a superior-quality aluminium, which optimally combines thermal and microphonic properties. The front panels are treated with solid 20mm-thick aluminium billets; heat sinks frame the side panels and 5mm plates cover the top and bottom surfaces of the products. The aluminium is brushed, sandblasted and anodised to guarantee unalterable beauty throughout the product's life. The New Classic range can be immediately distinguished with one look and one touch, before the first note of music even plays.
Upgrade your user experience!
Discover the new interface available for the 200 & 300 Series to help with the set-up of your products. Find high-quality tutorials to optimise the sound settings, best practice advice and tips.
Manuals & Downloads
Product Manuals
Brochures
Product Specification
Attribute Value
Product Type
Power Supply (for NVC TT)
Naim logo
White illuminated
Logo brightness: High, medium, low
Audio Outputs
Attribute Value
Power Outputs
Type 1, Type 2
Physical
Attribute Value
Weight
12.35lb (5.6kg)
Dimensions (HxWxD)
23/4x83/8x13" (7x21.4x33cm)
Power
Attribute Value
Mains Supply
110 to 120V, 220 to 240Vac
Power Consumption
<0.5W
Streaming and Ripping
Attribute Value
USB
Micro USB socket (for updates)
