NSC 333
Sleek design meets audiophile quality
NSC 222 is an easy-to-use streaming preamplifier with multiple functions, offering uncompromising sound quality. With its high-precision engineering and exclusive British design from Naim, this product brings you a world of streamed music and radio, handling vinyl and audio headphones, as well as creating a high-performance analog preamplifier. Combine it with the NAP 250 power amplifier for an exceptional assembly: just add loudspeakers
Begin your New Classic musical journey with the highly versatile NSC 222 preamplifier. Access a wide range of music streaming platforms (Spotify, TIDAL, Qobuz, etc.), a very large number of online radio stations, handling bitrates of up to 32bit/284kHz.
Want to enjoy vinyl? The NSC 222 has a MM phono input. Do you like headphones and want to dive into a world of solo listening? NSC 222 is also equipped with the full Naim technology for headphone listening, which is inherited from the Uniti Atom Headphone Edition: our amplifier-DAC, the recipient of several awards all around the world.
NSC 222 incorporates the very latest Naim streaming platform. Made by our experts in Salisbury, it sets new standards in terms of its prowess, functionality and ease of use. It is designed to offer true Hi-Fi performance, with the legendary Naim sound. Play all your favourite radio stations non-stop, as well as any music you choose from Spotify Connect, Apple Music, TIDAL, TIDAL Connect, Qobuz, AirPlay 2, Chromecast, UPnP™ servers, USB key, Roon Ready, and more.
_2_09831.jpg?itok=iRjFmOR4)
The Naim App – available for Apple and Android devices – makes it simple to control your NSC 222, and even link up other music systems around your home into a stunning multi-room set-up. Use the App to access all your music, including your favourite radio stations, streaming services and playlists, and explore artist discographies and biographies.
The NSC 222 is very simple to use – you can easily control it using the Focal & Naim app, available on iOS and Android, but also with the Zigbee smart remote control supplied. Of course, you can also access many features via the NSC 222 itself, and its backlit volume button. For your listening pleasure, the 5.5” colour screen displays the tracks being played.
Under the guidance of our Technical Director, Naim’s engineers have developed simple but elegant circuits, combined with our acclaimed and high-performing DR technology, guaranteeing the stable and fluid power supply so essential for superior performance. Our teams opt for the highest-quality components and perform ultra-precise measurements for an uncompromising result.
Naim products are designed to be both contemporary and timeless. Our creations forego any unnecessary decoration that does not contribute to performance targets or add to the sound quality. The design of the NSC 222 streamer and preamplifier combines extreme precision, impressive functionality, sleek design and innovative materials to make it easy and enjoyable to use.
Our founder, Julian Vereker, immediately understood the many benefits of aluminium as a material for wrapping Naim electronic components. He knew that delicate audio components are very sensitive to the effects of magnetic fields, unstable temperatures, unwanted vibrations, etc. While other manufacturers were bending thin sheets of steel, Naim used thick plates of aluminium.
The Naim Classic range maximises this highly technical and durable approach, with aluminium housings rivalled only by Statement, our flagship product. Naim chose a superior-quality aluminium, which optimally combines thermal and microphonic properties. The front panels are treated with solid 20mm-thick aluminium billets; heat sinks frame the side panels and 5mm plates cover the top and bottom surfaces of the products. The aluminium is brushed, sandblasted and anodised to guarantee unalterable beauty throughout the product's life. The New Classic range can be immediately distinguished with one look and one touch, before the first note of music even plays.
Manuals & Downloads
Declaration of Conformity
Product Manuals
Brochures
Product Specification
Attribute Value | |
Product Type |
Streamer |
Control |
App control (iOS and Android), bi-directional ZigBee remote and front panel. |
Attribute Value | |
Digital (S/PDIF) |
2 x Optical TOSLINK (up to 24bit/96kHz) |
Attribute Value | |
Distortion |
0.002% @0dBFS, 1kHz |
Distortion |
Digital: 0.002% @0dBFS, 1kHz, volume at 0dB, 1kHz |
Crosstalk |
Digital: 94dB at 1kHz, volume at 0dB |
Analogue |
1 x XLR pair (balanced, 2.1Vrms) |
Digital (S/PDIF) |
1 x coaxial BNC (up to 24bit 192kHz) |
Signal-to-Noise Ratio |
Digital: 108dB ref 0dBFS A-wtd, volume at 0dB |
Frequency Response |
Digital: 3Hz to 27kHz -3dB |
Attribute Value | |
Audio Formats |
WAV - up to 32bit/384kHz |
Attribute Value | |
Weight |
24.25lbs (11kg) |
Dimensions (HxWxD) |
35/8x17x121/2" (9.15x43.2x31.75cm) |
Attribute Value | |
Mains Supply |
115V or 230V, 50/60Hz |
Power Consumption |
Typical use consumption: 25W |
Attribute Value | |
Network Storage |
Ethernet (10/100Mbps), Wi-Fi (802.11 b/g/n/ac) |
USB |
2 x USB Type A socket (front and rear - 1.6A charge) |
