SNAXO 242
Upgrade your loudspeakers to active specification with our SNAXO 242 crossover. Suitable for use in biamplified systems, the SNAXO 242 will make the most of your amplifier’s output. Every model we sell is optimised before delivery to suit the specific requirements of your speakers.
- Suitable for use with two stereo, or four mono amplifiers
- Powered by FlatCap XS, HiCap or SuperCap power supply
The SNAXO 242 can be used in bi-amplified systems with two stereo amplifiers, or in a four-pack system using four mono amplifiers. Power to the unit is supplied by a FlatCap XS, HiCap or SuperCap audio power supply. When ordering a SNAXO, you should specify which loudspeaker model this will be used with, as we tailor the components within each SNAXO for use with specific loudspeakers. For more information contact your local Naim Audio retailer.
Product Specification
Attribute Value | |
Line Outputs Fixed (level) |
775mV |
Analogue |
4 x 4-pin DIN |
Minimum Load Impedance |
10kΩ |
Attribute Value | |
Case |
Black powder coated |
Front |
Bead blasted and black anodised |
Attribute Value | |
Shipping Dimensions |
210 x 280 x 410 mm |
Dimensions (HxWxD) |
87 x 207 x 314 mm |
Attribute Value | |
Power Supply Options |
FlatCap XS, HiCap, SuperCap |
Supply Voltage |
24V |
Attribute Value | |
Supplied with |
SNAIC |
Manuals & Downloads
Brochures
Product Manuals
Book a Demo
Find Your Nearest Retailer
Please complete the form below to arrange an appointment with your chosen retailer.
Newsletters Sign Up
