Uniti Atom
Enjoy sublime sound from all your favourite music and radio stations – even your TV – with the Uniti Atom streaming player. Award-winning performance combines with excellent build quality and usability, wrapped in a beautiful British design that will give you years of entertainment.
Uniti Atom expertly handles all the top music-streaming services – including Spotify, Apple Music, TIDAL and Qobuz – plus offers easy Apple AirPlay 2, Chromecast built-in and Bluetooth playback.
It can also seamlessly play with other music systems around your home, and connect to your TV via HDMI, so your favourite shows and movies sound better, too.
Master the Uniti Atom and explore a world of music via the Naim App; there is also voice-control support for Google Assistant and Apple Siri, and even a smart remote control handset.
The powerful Uniti Atom sounds magnificent with a wide range of loudspeakers – we suggest Focal as the perfect partner.
Enjoy all this, and more
Made to thrill. Built to Last.
Discover the new interface available for the Uniti products to help with the set-up of your products. Find high-quality tutorials to optimise the sound settings, best practice advice and tips.
Easy App control – in one room or many
The Naim App – available for Apple and Android devices – makes it simple to control your Uniti Atom, and even link up other music systems around your home into a stunning multi-room set-up.
Use the App to access all your music, including your favourite radio stations, streaming services and playlists, and explore artist discographies and biographies.
Uniti Atom works seamlessly with other Naim streaming products, including Mu-so systems. Choose the same song in beat-perfect sync or play different music in different rooms. You can also pair Uniti Atom with other AirPlay 2-compatible wireless speakers via the Apple Home app, or with other Chromecast built-in devices via the Google Home app.
Dimensions and Weight
95 mm x 245 mm x 265 mm (H x W x D)
7 kg
Connectivity
Audio Inputs
2 x Optical TOSLink (up to 24bit/96kHz)
1 x Coaxial RCA (up to 24bit/192kHz, DoP 64Fs)
1 x HDMI ARC
1 x RCA
2 x USB Type A socket (front and rear)
Audio Outputs
1 x Stereo power amplifier
1 x RCA sub/pre output
1 x 3.5mm headphone jack
Specifications
Attribute Value | |
Streaming |
Chromecast Built-In, Apple Airplay, TIDAL, Spotify® Connect, Bluetooth (AptX HD), Internet Radio™, UPnP™ (hi-res streaming), Roon Ready |
USB |
2 x USB Type A Socket (front and rear) |
Digital (S/PDIF) |
2 x Optical TOSLink (up to 24bit/96kHz) |
Attribute Value | |
Updates |
Update your system wirelessly via the Naim app. |
Network |
Ethernet (10/100Mbps), WiFi (802.11 b/g/n/ac with internal antennae) |
Attribute Value | |
Internet Radio Formats |
Windows Media-formatted content, MP3, ACC, OGG Vorbis streams and MMS |
Audio Formats |
WAV - up to 32bits/384kHz Notes: Gapless playback supported on all formats. |
Attribute Value | |
Dimensions |
95mm x 245mm x 265mm (HxWxD) |
Finishes |
Brushed and anodised aluminium |
Weight |
7kg |
Attribute Value | |
Auto Standby time |
User selectable: adjustable from off up to 2 hours |
Amplifier Output |
40W per channel into 8 ohms |
Mains Supply |
115V, 230V; 50 or 60Hz |
Power Consumption |
Typical use: 90W |
Attribute Value | |
Storage |
Store up to 20,000 tracks to a local USB connected storage device and serve to a network-connected player. |
Attribute Value | |
Supplied with |
Remote control, Power-Line Lite mains cable (UK denominations only), cleaning cloth and quick start guide. |
Attribute Value | |
Mains Cable |
Power-Line mains cable |
Amplification |
External power amplifier or sub-woofer |
Attribute Value | |
App Control |
Naim App for iOS and Android |
Front Panel |
5" colour TFT display and rotary volume control with proximity sensor and four buttons |
Handheld |
zigbee RF4CE |
Manuals & Downloads
Product Manuals
Brochures
Quick Start Guides
Suggested System
Reviews & Awards
Support
Register your Uniti Atom
Register your new Naim Uniti Atom with us to validate your warranty and to be kept informed of the latest available updates for your product.
