Chromecast built-in
New for Uniti is native support for Google’s latest technology, Chromecast built-in. This streaming service allows you to seamlessly link to hundreds of supported apps including Deezer, Qobuz, Plex, TuneIn, Soundcloud and Pandora from your smartphone or tablet and stream directly to Uniti.
AirPlay
Stream music from your iDevice or from iTunes and Apple Music.
TIDAL
The lossless streaming service is integrated into the system for an immersive, high-quality sound experience. Plus get a 90-day free trial of the lossless HiFi-tier service (terms and conditions apply).
Spotify® Connect
Discover millions of songs from the world’s most popular streaming service with the built-in Spotify Connect feature.
Bluetooth (aptX HD)
The new Uniti all-in-one players now feature aptX HD. Pair your Bluetooth device and instantly play back your music in high definition ‘better than CD’ quality.
Internet Radio™
Access thousands of internet radio stations and save your favourite pre-sets for easy access.
UPnP™ (Universal Plug ‘n’ Play)
Stream your stored music from a PC, Mac or network-attached storage in high-res ‘better than CD’ quality.
Digital Input (S/PDIF)
Boost audio from digital sources such as TVs, set top boxes or games consoles.
Analogue Output
For connection to an external power-amplifier or a sub-woofer.
Headphones
Front panel 3.5mm headphone jack with new upgraded headphone amplifier with significantly improved bass extension.
CD Playback and Ripping
Create bit-perfect copies of your CDs, save the data to a USB-connected storage device or an SD-card and then play back the music through your Uniti Star.
Storage
Store up to 20,000 tracks to a local USB-connected storage device or an SD-card and either play them back through your Uniti Star or serve them to other Naim streamers on your home network.
HDMI ARC
New Uniti all-in-one players feature an HDMI ARC input so you can easily connect your TV to experience audiophile sound quality from your favourite film or game.
Multiroom
New Uniti allows you to play music from any source in multiple rooms simultaneously – simply sync the units using the Naim control app. Or play different music in every room. You can also serve any music stored on your Uniti Atom to other Uniti all-in-one players or Naim streamers at full CD quality.
Roon Ready
Roon transforms the experience of browsing music. Beautifully laid-out metadata is located automatically, then interconnected by links to build a surfable, searchable digital magazine about your music collection.
Wireless Updates
Over-the-air updates via the Naim App now enable you to update your Uniti system at the touch of a button.
Qobuz
Qobuz allows you to stream the most comprehensive CD-quality music catalogue currently available and the largest selection of albums in true high-resolution studio quality directly to your Naim music streamer.
TIDAL Connect
TIDAL Connect allows you to stream directly from the feature-rich TIDAL App to your Naim product. Requires a TIDAL subscription.
