NAC 152 XS Separate Preamplifier
NAC 152 XS
Discontinued
Our entry-level separate preamplifier, the NAC 152 XS provides all the transparency and musicality you’d expect from Naim Audio, plus a long-term upgrade path to even better performance. The perfect alternative to an integrated amplifier, it’s an outstanding first step into the world of Naim Audio ownership.
Share
Features
  • Support for both DIN and RCA inputs to ease connection into a wide range of systems
  • User configurable unity-gain AV input
  • Full infrared remote control - RC5 input for wired remote control in complex installations
  • Optional RS232 input/output for use in full home automation systems
  • Can be powered from the preamp inputs of the NAP 155 XS or NAP 200 or external power supply (see Upgrade Path)
Technology & Craft
The NAC 152 XS, a replacement for the NAC 122x, is based on its larger brother the NAC 202 and features a hardwired motorised Alps volume control potentiometer delivering better performance and lower noise in use. The six DIN inputs are relay switched, improving performance. Much care in the design has been afforded to making the casework and PCB as low resonance as possible and to isolate the PCB from interference in its environment.
The NAC 152 XS features an additional output alongside the Naim Audio standard DINs. This stereo output on two RCA sockets is optimised for connection to an active subwoofer and supports the growing use of 2.1 systems. Its rear panel layout is similar to the NAC 202 and hence is Fraim friendly. The NAC 152 XS can be powered from the preamp power outputs of the NAP 155 XS or NAP 200 or can be upgraded by powering it from either a FlatCap XS or HiCap power supply. One of the DIN inputs can supply power to a Naim Audio StageLine outboard phono stage.
Product Specification
Audio Inputs
Attribute Value
Other Inputs
AV input configurable for unity gain
Input Impedance
47kΩ
Analogue Input
5 x DIN, RCA, 1 x DIN, 1 x 3.5mm jack
Input Sensitivity
130mV
Audio Outputs
Attribute Value
Other Outputs
1 x sub (RCA)
Line Outputs Variable (level)
775mV RMS
Line Outputs Fixed (level)
130mV, 600Ω
Load Impedance
10kΩ (min.)
Output Impedance
main <50Ω, sub <150Ω
Analogue
2 x variable (DIN), 1 x fixed (RCA)
Signal-to-Noise Ratio
67dB at 0.775V
THD
0.042% THD+N@1kHz, 2Vin, 0.0775V out
Power Outputs
Naim phono amplifier
Frequency Response
4Hz - 40kHz
Connectivity
Attribute Value
RS232
Optional (DE9 female)
Remote Input
1 x rear panel 3.5mm jack (RC5 modulated and unmodulated)
Finish
Attribute Value
Case
Black powder coated
Front
Brushed and black anodised
Physical
Attribute Value
Weight
3.8 kg
Dimensions (HxWxD)
70 x 432 x 301 mm
Power
Attribute Value
Power Supply Options
NAP 155 XS, NAP 200, FlatCap XS, HiCap, SuperCap
Supply Voltage
24V
Supplied with
Attribute Value
Supplied with
NARCOM-4 Remote Control
Upgrades
Attribute Value
Power Supply
FlatCap/HiCap
User Control
Attribute Value
Front Panel
Volume control, seven button matrix
Handheld
Remote Control
Infra Red (RC5)
Suggested System
  • ND5 XS
  • CD5 XS
Manuals & Downloads
Newsletters Sign Up
