NAC 202 Separate Preamplifier
NAC 202 | Discontinued
Classic Naim Audio control and clarity.
The NAC 202 is the next step up from our entry-level NAC 152 XS, adding star-earthed circuit boards for superior transparency and an even lower resonance circuit layout. It provides for a wide range of expansion and upgrade options, including connection to a StageLine phonostage and an AV bypass connection to an external AV amplifier.
Share
Features
  • Support for both DIN and RCA inputs to ease connection into a wider range of systems
  • User configurable unity-gain AV input
  • Powered input for use with StageLine or Prefix phono stage
  • RC5 input and Smart IR system for remote control integration of Naim Audio products
  • Optional RS232 input/output for use in full home automation systems
  • Can be powered from the preamp inputs of the NAP 155 XS or NAP 200 power amplifier or external power supply (see Upgrade Path)
Technology & Craft
The NAC 202 introduced a new level of technical and musical performance to our range of preamplifiers, along with elegant new styling.
Low-resonance circuit boards and anti-vibration, resonance controlling feet minimise the effect of microphonic vibration on the highly sensitive electronic components while carefully matched precision rotary potentiometers with precious metal wipers are used to preserve musical integrity and ensure long-term stability. The intelligent balance control combines a high quality motorised potentiometer for the best performance with intelligent circuitry to indicate the centre position.
The NAC 202 also features a silent microprocessor that sleeps during listening and controls all aspects of the amplifier including: protection circuits that continuously monitor the power supplies ensuring safe shut down in the event of a power cut; user-configurable RC5 input and Smart IR system for remote control integration of Naim Audio products.
Product Specification
Audio Inputs
Attribute Value
Other Inputs
AV input configurable for unity gain
Input Impedance
47kΩ
Analogue Input
4 x DIN, 2 x RCA
Input Sensitivity
75mV
Audio Outputs
Attribute Value
Line Outputs Variable (level)
775mV
Line Outputs Fixed (level)
75mV, 600Ω
Load Impedance
10kΩ (min.)
Output Impedance
<50Ω
Analogue
2 x variable (DIN), 3 x line level
Power Outputs
Naim phono amplifier
Connectivity
Attribute Value
RS232
Optional (DE9 female)
Remote Input
RCA on rear (RC5)
Finish
Attribute Value
Case
Black powder coated
Front
Brushed and black anodised
Physical
Attribute Value
Weight
7.0 kg
Dimensions (HxWxD)
87 x 432 x 314 mm
Power
Attribute Value
Power Supply Options
NAP 155 XS, NAP 200, FlatCap XS, HiCap, SuperCap
Supply Voltage
24V
Supplied with
Attribute Value
Supplied with
NARCOM-4 Remote Control
Upgrades
Attribute Value
Power Supply
1 x Hi-Cap/SuperCap
Other
NAPSC (optional)
User Control
Attribute Value
Front Panel
Volume control, eight button matrix
Handheld
Remote Control
Infra Red (RC5)
Suggested System
The NAC 202 is the entry into the world of Naim control amplifiers and creates a fantastic separates system when partnered with a NAP200. Star-earthed circuit boards and a low resonance circuit layout deliver superb transparency. The NAC202 provides for a wide range of expansion and upgrade options, including connection to a StageLine phono stage and an AV bypass for connection to an external AV amplifier.
  • NDX 2
Manuals & Downloads
Book a Demo
Find Your Nearest Retailer
Please complete the form below to arrange an appointment with your chosen retailer.
By submitting your contact details, you agree for us to share your details with our retail partners, who will contact you directly to arrange your appointment. For full details on how your data is shared please review our privacy policy
Customer Reviews
Newsletters Sign Up
