NAC 282 Separate Preamplifier
NAC 282 | Discontinued
Controlled performance.
Step up from the NAC 202 and you arrive at the outstanding NAC 282, which includes the NAPSC power supply unit optionally available on its sibling. The NAPSC independently powers the NAC 282’s digital and control circuits, leaving its audio circuits to either the power supply of a NAC 155 XS or NAP 200 power amplifier, or to one of our standalone FlatCap XS, HiCap or SuperCap power supplies. The result is even greater transparency and superior musicality plus, of course, all the flexibility you’d expect from one of our preamplifiers.
Share
Features
  • Support for both DIN and RCA inputs to facilitate connection into a wider range of systems
  • Silent microprocessor control that sleeps during listening
  • Precision rotary potentiometers with precious metal wipers
  • AV bypass mode for simple connection to an existing AV system
  • Powered input for use with StageLine or SuperLine phono stages
Performance upgradable with FlatCap XS, HiCap or SuperCap power supply; can also be powered from the preamp inputs of the NAP 155 XS or NAP 200 power amplifier
Technology & Craft
Low resonance circuit boards and anti-vibration, resonance control feet maximise isolation, hence minimizing the effects of microphonic vibration on the highly sensitive electronic components.
The NAC 282 features a silent microprocessor that sleeps during listening and controls all aspects of the amplifier. Optical protection circuits continuously monitor the power supplies ensuring safe shut-down in the event of a power cut.
A user configurable 'Smart IR' system remote control is supplied. Two of the six inputs on the Naim Audio NAC 282 can be configured either as the usual DIN inputs, preferred for their superior earthing and impedance matching, or for use with the more common RCA phono connectors, allowing a wide range of non-Naim Audio cables and components to be used. A dedicated unity-gain input is provided for use with the Naim Audio AV2 processor or similar.
Product Specification
Audio Inputs
Attribute Value
Other Inputs
AV input configurable for unity gain
Input Impedance
47kΩ
Analogue Input
4 x DIN, 2 x DIN, RCA
Input Sensitivity
75mV
Audio Outputs
Attribute Value
Audio Outputs
2 x variable (DIN), 3 x fixed (DIN)
Other Outputs
<50Ω
Line Outputs Variable (level)
775mV
Line Outputs Fixed (level)
75mV, 600Ω
Load Impedance
10kΩ (min.)
Power Outputs
Naim phono amplifier
Connectivity
Attribute Value
RS232
Optional (DE9 female)
Remote Input
RCA on rear (RC5)
Finish
Attribute Value
Case
Black powder coated
Front
Brushed and black anodised
Physical
Attribute Value
Weight
7.0 kg
Dimensions (HxWxD)
87 x 432 x 314 mm
Power
Attribute Value
Power Supply Options
NAP 155 XS, NAP 200, FlatCap XS, HiCap, SuperCap
Supply Voltage
18V, 24V
Supplied with
Attribute Value
Supplied with
NARCOM-4 Remote Control
Upgrades
Attribute Value
Power Supply
2 x Hi-Cap/SuperCap
Other
NAPSC
User Control
Attribute Value
Front Panel
Volume control, balance control, sixteen button matrix
Handheld
Remote Control
Infra Red (RC5)
Suggested System
A Naim Audio Retailer will recommend the right system for you, however you may choose to partner the NAC 282 with the following as a start:
  • XPS DR | Discontinued
  • Sopra
  • NDX 2
  • NAPSC
Manuals & Downloads
Book a Demo
Find Your Nearest Retailer
Please complete the form below to arrange an appointment with your chosen retailer.
By submitting your contact details, you agree for us to share your details with our retail partners, who will contact you directly to arrange your appointment. For full details on how your data is shared please review our privacy policy
Customer Reviews
Newsletters Sign Up
