NAIT 5si Integrated Amplifier
NAIT 5SI
Redefining an icon.
The NAIT 5si is our 60W per channel introduction to high-performance integrated amplification. Another Naim Audio amplifier that can claim a common heritage with our classic NAIT model, the NAIT 5si will get straight to the heart of your music. It engages even the most complex rhythms and demanding dynamics with all the grip and authority you would expect from us. Its clever AV bypass mode, which facilitates an easy co-existence of otherwise distinct AV and hi-fi systems, simply adds to its appeal.
Share
Features
  • 60W per channel power output
  • Four inputs with support for both DIN and RCA connections
  • 1/4” (6.35mm) headphone output
  • AV bypass mode for simple connection to an existing AV system
Technology & Craft
Decades have passed, but the role of the NAIT 5si is fundamentally the same as its original forebear. So the engineering challenge - to maximise performance whilst maintaining engineering efficiency, quality and reliability - hasn't changed. Amplifier technology has moved on considerably however, and while the NAIT 5si occupies the same position in the Naim Audio range as the original NAIT, its performance might be from a different world.
The NAIT 5si provides four analogue inputs and a 60 Watt per channel power amplifier. It borrows numerous technologies from across the spectrum of Naim Audio products; all dedicated towards maximising its ability to communicate the fundamentals of music. And communicate it does. The NAIT 5si brings clarity, engaging dynamics and, most of all, infectious enthusiasm to every music source and genre.
Product Specification
Audio Inputs
Attribute Value
Input Impedance
20kΩ
Analogue Input
2 x DIN, 4 x RCA
Input Sensitivity
150mV
Audio Outputs
Attribute Value
Audio Outputs
Speakers, HDD
Other Outputs
Headphone, 1/4" jack
Line Outputs Fixed (level)
150mV, 600Ω
Finish
Attribute Value
Case
Black powder coated
Front
Black powder coated
Physical
Attribute Value
Shipping Weight
8.6 kg
Shipping Dimensions
200 x 590 x 500 mm
Weight
6.8 kg
Dimensions (HxWxD)
70 x 432 x 301 mm
Power
Attribute Value
Power Consumption (max.)
300VA
Mains Supply
100V, 115V, 230V; 50 or 60Hz
Power Consumption (quiescent)
19VA
Speaker Outputs
Attribute Value
Power Output
60W/channel, 8Ω
Transient
300VA
Supplied with
Attribute Value
Supplied with
NARCOM-4 Remote Control, Power-Line Lite mains cable (UK denominations only)
User Control
Attribute Value
Front Panel
Volume Control, four button matrix
Remote Control
Infra Red (RC5)
Suggested System
A Naim Audio Retailer will recommend the right system for you, however you may choose to partner the NAIT 5si with the following as a start:
  • ND5 XS
  • CD5si
  • Aria 900
Manuals & Downloads
Book a Demo
Find Your Nearest Retailer
Please complete the form below to arrange an appointment with your chosen retailer.
By submitting your contact details, you agree for us to share your details with our retail partners, who will contact you directly to arrange your appointment. For full details on how your data is shared please review our privacy policy
Customer Reviews
Newsletters Sign Up
