NPX 300
Optimised power and performance
Reach a higher level of musical performance with the NPX 300 power supply for the 200 Series sources and preamplifiers, including the NSC 222 streaming preamplifier.
NPX 300 deactivates the internal power supply, immediately reducing noise, and provides a superior, cleaner power supply. You can connect several NPX 300 power supplies within the same configuration for an exceptional musical experience.
The NPX 300 powers your system in a silent, fluid way, allowing the preamplifier to concentrate on its main task: controlling the signal. In addition to improving the performance of the NSC 222 preamplifier and streamer, the NPX 300 can be used to upgrade several Naim products, lending them immense flexibility over time.
The NPX 300 incorporates a new transformer, which works with six exclusive Naim power regulators (DR technology - Discrete Regulator), providing a cleaner power to your system. Less “noise” means a better sound!
It works perfectly with the 200 Series products, and is also compatible with the NDX2 or even the NAC-N 272 – you just need the specific cables.
At Naim, all our choices are made with the aim of creating a unique emotional connection with music,and offering you the best products in their category. The NPX300 includes a certain number of innovations used on the flagship Naim 555PS DR power supply, such as the separation of the digital and analog power supplies via dedicated Burndy cables.
Our founder, Julian Vereker, immediately understood the many benefits of aluminium as a material for wrapping Naim electronic components. He knew that delicate audio components are very sensitive to the effects of magnetic fields, unstable temperatures, unwanted vibrations, etc. While other manufacturers were bending thin sheets of steel, Naim used thick plates of aluminium.
The Naim Classic range maximises this highly technical and durable approach, with aluminium housings rivalled only by Statement, our flagship product. Naim chose a superior-quality aluminium, which optimally combines thermal and microphonic properties. The front panels are treated with solid 20mm-thick aluminium billets; heat sinks frame the side panels and 5mm plates cover the top and bottom surfaces of the products. The aluminium is brushed, sandblasted and anodised to guarantee unalterable beauty throughout the product's life. The New Classic range can be immediately distinguished with one look and one touch, before the first note of music even plays.
Discover the new interface available for the 200 & 300 Series to help with the set-up of your products. Find high-quality tutorials to optimise the sound settings, best practice advice and tips.
Manuals & Downloads
Product Specification
Attribute Value | |
Naim logo |
White illuminated |
Connectivity |
Micro USB (update only) |
Attribute Value | |
Weight |
31.75lbs (14.4kg) |
Dimensions (HxWxD) |
35/8x17x121/2" (9.15 x 43.2 x 31.75cm) |
Attribute Value | |
Mains Supply |
115V or 230V, 50/60Hz |
Power Output |
Type 3, Type 4 |
Power Consumption |
Standby <0,5W |
Attribute Value | |
Type |
Power supply |
