Uniti Atom Headphone Edition
如家般的放松享受,清静无干扰
Uniti Atom 耳机可以将任何空间转换为您自己的音之茧。典型的耳机放大器需要连接至电脑,而 Uniti Atom 耳机集所有智能于一身,并可享用 Naim 独家流媒体平台。此外,Uniti Atom 最佳耳机系列荣获多个奖项,采用平衡 4 针 XLR 和 4.4 毫米(Pentaconn)输出;6.3 毫米输出,可兼容多个型号耳机–我们建议 Focal 作为最佳搭配。更加灵活,根据音源和听取位置,最多可插入三个耳机和开关。
截上耳机充分享受您专属的数字音乐库、最喜欢的电台和播客,以及 Spotify, Apple music、 Tidal 和 qobz 音乐,令您生活更惬意。还可以通过 Apple AirPlay 2 和 Chromecast内置设备与您的所有设备直接无线传输数据,连接唱盘与 U 盘连接传输数据。通过 Naim 应用程序探索和管理所有选项。
如果您想享受震撼音乐时,它还可充当紧凑式流式前置功放使用。只需添加有源音箱,或功率放大器和音箱组成即时系统。
享受这一切,以及更多
  • Chromecast built-in
    New for Uniti is native support for Google’s latest technology, Chromecast built-in. This streaming service allows you to seamlessly link to hundreds of supported apps including Deezer, Qobuz, Plex, TuneIn, Soundcloud and Pandora from your smartphone or tablet and stream directly to Uniti.
  • AirPlay
    Stream music from your iDevice or from iTunes and Apple Music.
  • TIDAL
    The lossless streaming service is integrated into the system for an immersive, high-quality sound experience. Plus get a 90-day free trial of the lossless HiFi-tier service (terms and conditions apply).
  • Spotify® Connect
    Discover millions of songs from the world’s most popular streaming service with the built-in Spotify Connect feature.
  • Bluetooth (aptX HD)
    The new Uniti all-in-one players now feature aptX HD. Pair your Bluetooth device and instantly play back your music in high definition quality.
  • Internet Radio
    Access thousands of internet radio stations and save your favourite pre-sets for easy access.
  • UPnP (Universal Plug ‘n’ Play)
    Stream your stored music from a PC, Mac or network-attached storage in high-res ‘better than CD’ quality.
  • Digital Input (S/PDIF)
    Boost audio from digital sources such as TVs, set top boxes or games consoles.
  • Analogue Output
    For connection to an external power-amplifier or a sub-woofer.
  • Headphones
    Balanced 4-pin XLR and 4.4mm (Pentaconn) outputs; 6.3mm output
  • Storage
    Store up to 20,000 tracks to a local USB-connected storage device and either play them back through your Uniti Atom or serve them to other Naim streamers on your home network.
  • Multiroom
    New Uniti allows you to play music from any source in multiple rooms simultaneously – simply sync the units using the Naim control app. Or play different music in every room. You can also serve any music stored on your Uniti Atom to other Uniti all-in-one players or Naim streamers at full CD quality.
  • File Formats
    Supports a broad range of music formats including WAV, FLAC, DSD, Apple Lossless, AIFF, AAC, Windows Media-formatted files, Ogg Vorbis and MP3.
  • Wireless Updates
    Over-the-air updates via the Naim App now enable you to update your Uniti system at the touch of a button.
  • Roon Ready
    Roon transforms the experience of browsing music. Beautifully laid-out metadata is located automatically, then interconnected by links to build a surfable, searchable digital magazine about your music collection.
  • Qobuz
    Qobuz allows you to stream the most comprehensive CD-quality music catalogue currently available and the largest selection of albums in true high-resolution studio quality directly to your Naim music streamer.
0%
搜寻零售商
应用控制简单便利 - 一个房间或多个房间
Naim 应用可用于苹果和 Android 设备,可简便地控制您的 Uniti Atom 耳机,甚至可以将家中的其他音乐系统连接至震撼的多房间设置中。
使用该应用可以访问所有音乐,包括您喜爱的广播电台、流媒体服务和播放列表,并且可浏览艺术家的唱片和介绍。
Uniti Atom 耳机可与 Mu-so 系统等其他 Naim 流媒体产品无缝搭配使用。在 Beat-Perfect Sync 中选择同一首歌曲,或在不同的房间播放不同的音乐。此外,可以通过 Apple Home 应用程序将 Uniti Atom 耳机与其他 AirPlay 2 兼容的无线扬声器配对,或者通过 Google Home 应用程序与其他内置 Chromecast 设备配对。
尺寸和重量
95 mm x 245 mm x 265 mm (高 x 宽 x 深)
7 kg
Connectivity
Network: Ethernet (10/100Mbps)
WiFi (802.11 b/g/n/ac with internal antennae)
Multiroom: Sync up to five Naim Streaming products and control via the Naim App.
音频输入
数字:2 x 光学 S/PDIF(最高达 96kHz),同轴 RCA(最高达 24bit/192kHz, DoP 64Fs
模拟:1 对立体声 RCA
USB 接口:2 个 USB 2.0 接口(A 型接头)
流式传输: Apple AirPlay 2、Chromecast Built-in、 UPnPTM、Spotify® Connect、TIDAL、Roon Ready、Bluetooth、Internet Radio、Qobuz
音频输出
平衡 XLR 前置功放输出端
RCA 前置功放输出端
耳机输出
4.4mm Pentaconn(平衡)4 针 XLR(平衡) 6.35mm (¼ inch)千斤顶(不平衡)
每通道 1.5W RMS 到 16hms
适用于电阻 16hms 以上的耳机
规格
提供:文件包、清洁布、遥控器、AAA 电池和电源线。
功率
典型功耗:17W
网络待机模式: 非网络待机模式: 用户可选择自动待机时间:从关机到 2 小时可调
电源
115V、230V;50或60Hz
建议系统
  • Radiance
  • Focal Utopia
  • Focal Stellia
  • Focal Clear Mg
  • Focal Celestee
支援
