Uniti Atom Headphone Edition
Relax at home, without distractions
The Uniti Atom Headphone Edition can transform any space into your own audio cocoon. Where typical headphone amplifiers demand tethering to a computer the Uniti Atom Headphone Edition has all the brains – and Naim’s exclusive streaming platform. The headphone-optimised version of the multi-award-wining Uniti Atom also features Balanced 4-pin XLR and 4.4mm (Pentaconn) outputs; 6.3mm output, plus is compatible with an array of headphones – we suggest Focal as the perfect partner. Offering yet more flexibility, you can keep up to three headphones plugged in and switch sets depending on what you’re listening to and when.
Stream your own digital music library, favourite radio stations and podcasts, and music from Spotify, Apple Music, Tidal and Qobuz through your headphones without life disturbing you. Also wirelessly stream direct from all your devices via Apple AirPlay 2 and Chromecast built-in, plus connect other sources, from turntables to USB drives. Explore and curate all these choices via the Naim App.
For when you want to listen out loud, it also excels as a compact streaming pre-amplifier. Just add active speakers, or a power amplifier and speakers – for an instant system.
Enjoy all this, and more
Easy App control – in one room or many
The Naim App – available for Apple and Android devices – makes it simple to control your Uniti Atom Headphone Edition, and even link up other music systems around your home into a stunning multi-room set-up.
Use the App to access all your music, including your favourite radio stations, streaming services and playlists, and explore artist discographies and biographies.
Uniti Atom Headphone Edition works seamlessly with other Naim streaming products, including Mu-so systems. Choose the same song in beat-perfect sync or play different music in different rooms. You can also pair Uniti Atom Headphone Edition with other AirPlay 2-compatible wireless speakers via the Apple Home app, or with other Chromecast built-in devices via the Google Home app.
Dimensions and Weight
95 mm x 245 mm x 265 mm (H x W x D)
7 kg
Connectivity
Network: Ethernet (10/100Mbps)
WiFi (802.11 b/g/n/ac with internal antennae)
Multiroom: Sync up to five Naim Streaming products and control via the Naim App.
Audio Inputs
Digital: 2x Optical S/PDIF up to 96kHz, Coaxial RCA (up to 24bit/192kHz, DoP 64Fs)
Analogue: 1 x Stereo RCA pair
USB: 2x USB 2.0 (Type A connector)
Streaming: Apple AirPlay 2, Chromecast Built-in, UPnPTM, Spotify® Connect, TIDAL, Roon Ready, Bluetooth, Internet Radio, Qobuz
Audio Outputs
Balanced XLR Preamp output
RCA Preamp output
Headphone Outputs
4.4mm Pentaconn (balanced) 4 pin XLR (balanced) 6.35mm (¼ inch) jack (unbalanced)
1.5W RMS per channel into 16ohms
Suitable for headphones from 16ohms and upwards
Specifications
Supplied with: Document pack, cleaning cloth, remote, AAA batteries and power lead.
Power
Power Consumption Typical use: 17W
Network Standby mode:
No-network Standby mode:
Auto Standby time User selectable: adjustable from off up to 2 hour
Mains Supply
115V, 230V; 50 or 60Hz
Suggested System
Reviews & Awards
Support
Register your Uniti Atom Headphone Edition
Register your new Naim Uniti Atom Headphone Edition with us to validate your warranty and to be kept informed of the latest available updates for your product.
