NAP 200 Power Amplifier
NAP 200 DR | discontinued
The original Naim Audio amplifier.
First designed by Naim Audio founder Julian Vereker in 1971, the NAP 200 has Naim Audio musicality written into its DNA. As our first production amplifier, no single product encapsulates our philosophy better. Its design is simple and uncompromising, with a single-minded focus on one thing: creating an enduring musical connection with the listener.
More recently the NAP 200 has benefitted from the years of research that went into the NAP 500 amplifier. Many of the developments from the 500 Series project have helped to revitalise its electronic design and componentry bringing significant and hard-earned gains to performance. Beneath this new technology however, it retains the values which helped to make it an icon: simplicity, focus and sheer musicality.
New Technology
The NAP 200 has been revitalised and reintroduced in 2015 with the addition of a Naim Audio DR (Discrete Regulator) module to power its partnered Naim Audio preamplifier.  This comes alongside small improvements to some internal componentry and layout that combine to lift its musical performance even further than the original.
Share
Features
  • 70W per channel output into 8 Ohms
  • Large custom-designed transformer providing 300VA of transient power
  • Internal power supply to allow direct connection of a NAC 152 XS, NAC 202 or NAC 282 preamplifier
NAP 200 Power Amplifier - Rear View
Technology & Craft
Like the flagship NAP 500, the NAP 200 uses a new circuit design with improved earthing arrangements built on a very high quality, anti-resonance main audio circuit board. Anti-vibration, resonance-controlling feet serve to protect the sensitive internal components from microphonic vibration and unwanted external interference.
A new, top-quality 430VA toroidal transformer provides more than 300VA of transient power. Separate windings provide dedicated left and right channel rectified power supplies with two smoothing capacitors per channel. The NAP 200 also has a separate winding providing a preamplifier power supply. This enables it to be used in a two-box amplifier configuration with a Naim Audio preamplifier such as the NAC 202. The Naim Audio NAP 200 is stable into any load and can drive a 2-ohm load for long periods of time.
Product Specification
Audio Inputs
Attribute Value
Input Impedance
18kΩ
Analogue Input
1 x 4-pin DIN
Audio Outputs
Attribute Value
Minimum Load Impedance
Power Outputs
Naim pre-amplifier
Frequency Response
 -3dB at 3Hz - 50kHz
Gain
+29dB
Finish
Attribute Value
Case
Black powder coated
Front
Brushed and black anodised
Physical
Attribute Value
Shipping Weight
14.2kg
Shipping Dimensions
240 x 590 x 500 mm
Weight
11.6 kg
Dimensions (HxWxD)
87 x 432 x 314 mm
Power
Attribute Value
Mains Supply
100V, 115V, 230V; 50 or 60Hz
Power Consumption
11VA
Speaker Outputs
Attribute Value
Power Output
70W/channel, 8Ω
Transient
300VA
Speaker Outputs
L & R, 4mm “banana” sockets
Supplied with
Attribute Value
Supplied with
SNAIC, Power-Line Lite mains cable (UK denominations only)
Suggested System
A Naim Audio Retailer will recommend the right system for you, however you may choose to partner the NAP 200 with the following as a start:
  • Sopra
  • NDX 2
  • NAC 202 | Discontinued
  • HiCap DR | Discontinued
Manuals & Downloads
Reviews & Awards
Latest Reviews
NAP 200 DR | Hi-Fi World, Apr 2016
'A fine upgrade to an already impressive power amplifier. Brings added delicacy and depth with no loss of dynamism.'
Naim DR power amps and upgrades l HiFi+, Jan 2016
'The effectiveness of a regulated supply in cleaning up this crucial part of the circuit was immediately obvious...'
Book a Demo
Find Your Nearest Retailer
Please complete the form below to arrange an appointment with your chosen retailer.
By submitting your contact details, you agree for us to share your details with our retail partners, who will contact you directly to arrange your appointment. For full details on how your data is shared please review our privacy policy
Customer Reviews
Newsletters Sign Up
